Upgrade 1961 Plymouth Valiant front end to 1962 Plymouth Valiant front end
https://slantsix.org/forum/viewtopic.php?t=67981
Author:  crickhollow [ Fri Nov 08, 2024 9:17 pm ]
Post subject:  Upgrade 1961 Plymouth Valiant front end to 1962 Plymouth Valiant front end
It is hard to find lower control arm bushes for the 1961 Plymouth Valiant.
What is involved in upgrading to a 62' Plymouth Valiant front end?
Thanks
Author:  Greg Ondayko [ Sat Nov 09, 2024 4:07 am ]
Post subject:  Re: Upgrade 1961 Plymouth Valiant front end to 1962 Plymouth Valiant front end
You need the entire k frame and steering box, engine mounts, and lower control arms.
Possibly strut rods, and upper control arms, spindles.
Not sure on the steering linkages/ center link/ pitman arms/ idler arms.
The swap will work with any slant 6 k frame in a '66-'62 A body.
Steering column might need swapped as well.
Author:  SlantSixDan [ Sat Nov 09, 2024 2:17 pm ]
All different between ['60-'61] and ['62-'66].
Yep.
