Mystery Comp Cams ID?
https://slantsix.org/forum/viewtopic.php?t=68052
Page 1 of 1
Author:  Greg Ondayko [ Sat Jan 11, 2025 4:55 pm ]
Post subject:  Mystery Comp Cams ID?
Does anyone have old slant 6 comp cams information or listings?
Looking for more information on a cam that has 0.426" Lift on the intake Valve.
I know that is not much to go on.
Author:  MadScientistMatt [ Sun Jan 12, 2025 5:25 am ]
Post subject:  Re: Mystery Comp Cams ID?
Maybe you have a 252H? Intake lift is off by 1/1000".
https://www.compcams.com/high-energy-20 ... inder.html
Author:  Greg Ondayko [ Sun Jan 12, 2025 7:03 am ]
Thanks, Matt.
I was told that it was a solid Lifter cam, But that information and link you sent is sure real close.
This was a mystery cam installed in an engine with a bunch of other slanted parts in one of those "buy this, and get everything with it" bulk buys!
I am sure we don't want to run a Hydraulic Cam with Solid lifters, pushrods and valve gear. So I may have more investigation to do.
I should have measured the Duration at 0.050" on the Intake and Exhaust and the exhaust lift, but I failed to gather that date with my wheel and micrometer.
That would have given me more information to be precise on all of this.
Author:  slantzilla [ Sun Jan 12, 2025 12:03 pm ]
Probably a 252S. Seems like I had one on the shelf at the shop.
Author:  Greg Ondayko [ Sun Jan 12, 2025 2:40 pm ]
Hi Dennis, are there any specification sheets available for that cam?
Is it older and not in production any longer?
Author:  Will [ Tue Jan 14, 2025 3:42 pm ]
I have that cam card.
I will send you a text.
Will
Author:  Greg Ondayko [ Tue Jan 14, 2025 4:16 pm ]
Will
Got it. Thanks Will.
