| Looking for mechanic / engine rebuild shop recommendation - Spokane WA https://slantsix.org/forum/viewtopic.php?t=68062 |
| Author: | Jim's Valiant [ Mon Jan 20, 2025 2:25 pm ] |
| Post subject: | Looking for mechanic / engine rebuild shop recommendation - Spokane WA |
Hello all. My friend Jim owns a '62 Valiant. It's been sitting awhile, and he wants to go through various systems to make the car roadworthy. Does anyone on the Slant Six Forum have recommendations for a trusted mechanic and / or engine rebuild shop in Spokane, Washington? Thank you, Gary |
| Author: | volaredon [ Mon Jan 20, 2025 6:07 pm ] |
| Post subject: | Re: Looking for mechanic / engine rebuild shop recommendation - Spokane WA |
Reed? Halfafish? These are/6 fans I know of from this forum that are out that way. Plus a few others who haven't posted anything here in awhile so I won't mention them right now |
| Author: | Reed [ Mon Jan 20, 2025 9:25 pm ] |
Sorry, I am in Tacoma, on the other side of the State from Spokane. In don't get over there often enough to know of any good shops for old cars. That said, these are fairly simple vehicles. You can do quite a bit yourself with a factory service manual and a decent set of tools (and a somewhat deep wallet, these days). |
| Author: | curmudgeon [ Tue Jan 21, 2025 6:59 am ] |
PM sent. |
| Author: | Jim's Valiant [ Thu Jan 23, 2025 6:19 pm ] |
Thank you to all who responded. curmudgeon, I will PM you soon, thank you for reaching out. Gary |
| Author: | EC_CO [ Thu Jan 23, 2025 7:45 pm ] |
S&J Engines is out of Spokane, they are a large rebuilder and regularly do crate 225s. Being local, they'll probably do your block if you prefer https://www.sandjengines.com/ https://www.sandjengines.com/searchprod ... EW6gh8hnx4 I grew up and spent half my life in Spokane, the Barracuda I'm restoring was my dad's and it lived in that area since 73. |
| Author: | Jim's Valiant [ Sat Feb 01, 2025 4:21 pm ] |
Hello EC_CO. The S & J Engine shout out is super helpful...thank you! I will pass this information on to my friend Jim. https://www.sandjengines.com/ https://www.sandjengines.com/searchprod ... EW6gh8hnx4 I grew up and spent half my life in Spokane, the Barracuda I'm restoring was my dad's and it lived in that area since 73. S & J is literally a 10 minute drive from his house. I read on this forum where you have done a lot of work on the car you acquired from your dad. Spokane winters can be pretty rough on a car out in the elements. Yesterday I spoke with Jim and he told me his list for refreshing his '62 Valiant: Motor Transmission (push button automatic - shift kit if possible?) Brakes - Front disc brake conversion (if possible?) Shocks 14" wheel / tire combo with chrome moon hubcaps He also said he thinks the carburetor is a single barrel, and that he would like to do a intake manifold & 2 (or 4?) barrel carburetor conversion. If anyone has thoughts or input on the list (what may or may not be possible, shop referrals, etc.) please chime in. Thanks, Gary |
| Author: | EC_CO [ Sun Feb 02, 2025 12:49 pm ] |
Glad I could help, sounds like an ideal situation since he lives so close. Thankfully on my Barracuda the rust issues weren't too terribly bad, though still not cheap. My total paint and body costs are about 17 grand, I should have it back from paint at the end of this month. Others that are more knowledgeable will chime in, he certainly has both two barrel and four barrel options available, but my guess is the two bbl upgrade would do him just fine. |
| Author: | Greg Ondayko [ Sun Feb 02, 2025 4:15 pm ] |
Whatever you do or shop you choose.. Demand that they use a high quality timing set such as a rollmaster from australia, regularly available on eBay from falcon global. Also ask that they degree your cam even for a stock rebuild. The dot method of setting timing according to the FSM no longer works with questionable cheap timing sets and other mix n match possibly older parts. The extra cost af these small parts and services will help your overall slanting experience. Good luck! Greg |
| Author: | Charrlie_S [ Sun Feb 02, 2025 4:58 pm ] |
Don't forget about checking the sprocket alignment
Demand that they use a high quality timing set such as a rollmaster from australia, regularly available on eBay from falcon global. Also ask that they degree your cam even for a stock rebuild. Good luck! Greg |
| Author: | Greg Ondayko [ Sun Feb 02, 2025 5:18 pm ] |
Quote: Don't forget about checking the sprocket alignment Fore / aft on the crank sprocket? |
| Author: | Charrlie_S [ Sun Feb 02, 2025 5:41 pm ] |
Quote: Quote: Don't forget about checking the sprocket alignment Fore / aft on the crank sprocket? https://www.youtube.com/watch?v=_tXj5spK1NE |
| Author: | Greg Ondayko [ Sun Feb 02, 2025 5:46 pm ] |
Quote: Quote: Quote: Don't forget about checking the sprocket alignment Fore / aft on the crank sprocket? |
| Author: | Rick Covalt [ Sun Feb 02, 2025 8:38 pm ] |
Yes, mine had to be cut in order to get the crank gear on farther. Seems like it was .060 or .080" |
