Shock Spring Mounting Plates Needed 8 3/4
https://slantsix.org/forum/viewtopic.php?t=68130
Author:  hyper_pak [ Fri Mar 21, 2025 3:36 pm ]
Post subject:  Shock Spring Mounting Plates Needed 8 3/4
I understand 8 1/4 to Dana 60 will fit.
I will take the U Bolts also if you have them in good shape.
I have a set of 7 1/4 if that means anything to anyone.
Author:  slantzilla [ Sat Mar 22, 2025 7:05 pm ]
Post subject:  Re: Shock Spring Mounting Plates Needed 8 3/4
Last I knew Dr. Diff had them.listed as well as Mancini. :mrgreen:
Author:  Greg Ondayko [ Sun Mar 23, 2025 6:05 am ]
I have found Some Real nice ones on eBay that last time I bought some.
Yes Mancini Racing Have them but the do not look stock, Firm feel and others may have them too!
About $100 a pair Fully detailed, and then I used RockAuto or a local spring Shop for the 3" U Bolts.
Author:  hyper_pak [ Sun Mar 23, 2025 12:08 pm ]
Post subject:  FOUND Shock Spring Mounting Plates Needed 8 3/4
Don't have time to hunt through 9 million items on ebay much anymore.
I found a set.
