Slant six oil dipsticks and tubes, power steering pump bracket
https://slantsix.org/forum/viewtopic.php?t=68136
Author:  Reed [ Sun Mar 23, 2025 10:30 pm ]
Post subject:  Slant six oil dipsticks and tubes, power steering pump bracket
Selling some bits and pieces I have accumulated over the years. Trying to make space for new projects. Pictures tomorrow.
Two mid A body 225 engine dipsticks and tubes.
One set power steering pump brackets for a slant.
Several alternator brackets, two a body, one F body, I think
Oil pump splash guards, about five of them
Factory cam and lifters, I think from a 1963 225
Another unknown factory cam
I have a box of oil pumps with no drive gears, all pulled from running motors, should be considered cores. Let me know if you know where to buy slant oil pump drive gears.
I will add more as I find and sort it.
Prices are best offer. Money is nice but space is nicer. I am happy to pass these parts along to someone who can use them.
You pick up from my garage in Tacoma, WA or pay shipping. I will ship usps flat rate when I can.
Author:  EC_CO [ Mon Mar 24, 2025 6:22 pm ]
Post subject:  Re: Slant six oil dipsticks and tubes, power steering pump bracket
I'm looking for AC brackets if you run across anything in the stash
Author:  Reed [ Mon Mar 24, 2025 10:02 pm ]
Actually, I believe I have a complete AC system I pulled from a Duster in a junkyard about 20 years ago. It uses the older V-twin compressor, but I think I have everything- compressor, condenser, under-dash evaporator unit, everything but the hoses and receiver/dryer. Shipping would be expensive, but I would sell the whole setup.
Let me know if you are interested and I will dig it out of my attic.
Author:  EC_CO [ Thu Mar 27, 2025 6:46 am ]
I plan on installing a vintage air unit on my e-body, so I only need the brackets.
Author:  Reed [ Thu Mar 27, 2025 9:51 am ]
OK, I will check and see if my memory is accurate. I haven't touched the boxes in years and need to make sure I am remembering correctly.
Author:  Bsa6364 [ Fri Apr 25, 2025 11:38 pm ]
I’m looking for an early a body slant oil pan and pickup tube (62-66). If you happen to come across one or both, shout it out? Also, an early valve cover with the lines pressed into the top (early 62-66ish or later 67-69ish type is fine)Thx!
Author:  Reed [ Sat Apr 26, 2025 11:50 am ]
Nope, I have none of those. Sorry.
Author:  Charrlie_S [ Sat Apr 26, 2025 12:51 pm ]
Where are you located? I don't have any oil pans to let go of, but I should have a valve cover.
