| How to connect an electronic tach with the HEI conversion? https://slantsix.org/forum/viewtopic.php?t=68166 |
| Author: | Eatkinson [ Thu Apr 17, 2025 1:40 pm ] |
| Post subject: | How to connect an electronic tach with the HEI conversion? |
Need to connect my electronic Actron tach to do some carburetor and idle speed adjustment fine-tuning. In the past, you’d hook one tach lead to the ignition coil negative terminal (if memory serves). But since that time, I upgraded the ignition to the GM HEI setup and now I’m unsure where that tach lead gets hooked. I followed the excellent HEI conversion procedure write up from SSDan on this site. Who can tell me where it goes now? |
| Author: | eric22t [ Thu Apr 17, 2025 1:53 pm ] |
| Post subject: | Re: How to connect an electronic tach with the HEI conversion? |
terminal b on the coil. there is an excellent picture in dan's article |
| Author: | Eatkinson [ Fri Apr 18, 2025 9:41 am ] |
Thank you. I haven't re-read that article in awhile. |
| Author: | eric22t [ Fri Apr 18, 2025 10:47 am ] |
you're welcome. i kinda thought you might have not gone back lol |
