It is currently Fri Oct 23, 2026 8:25 pm
PostPosted: Wed Apr 30, 2025 8:35 am
I need both a Radiator and a Clutch.
1976 Dart, slant six.
Radiator yoke pattern is 22 wide, 14 tall, bolt hole to bolt hole.
Upper hose is center or left and left bottom.
I need a clutch also.
Brewer used to offer a package, but now you have to buy a flywheel with a GM pattern.
I guess that is ok, but cost goes way up.
I don't want a RockAuto replace every year unit.
Ideas on either are welcome.
Thanks!
PostPosted: Wed Apr 30, 2025 8:44 am
Check the dimensions. This might work for you.
https://www.ebay.com/itm/403727821072?_ ... p_homepage
PostPosted: Wed Apr 30, 2025 10:33 am
Thanks Charrlie that looks close.
PostPosted: Wed Apr 30, 2025 10:34 am
RA usually has a few to pick from.
I have never had a problem with LuK clutch which ive gotten several from them
The one brand I have had problems with and their name is (for lack of a better way to put it) a lie....
That brand is "perfection"... In reality they're far from that.
PostPosted: Wed Apr 30, 2025 11:36 am
I like Champion radiators and they should have one for you. I bought one for my 68 Dart. Very high quality.
PostPosted: Wed Apr 30, 2025 12:13 pm
Rock Auto has a 10 inch clutch with a picture that says Bork and Beck.
That one could have springs added to make a serious clutch.
If you get what they show.
PostPosted: Wed Apr 30, 2025 12:14 pm
Thanks Lou, I will look at them.
PostPosted: Wed Apr 30, 2025 12:21 pm
Check with Falcon Clutch
https://www.falconauto.com/
I am sure he can build what you need.
He resurfaced some pp's for me and refaced used / worn out clutch discs.
Champion Radiator has a rad for your car. It will be AL and not look correct.
PostPosted: Wed Apr 30, 2025 1:49 pm
Radiator, see here. This goes along with your stated philosophy of not wanting to buy junk.
PostPosted: Wed Apr 30, 2025 3:04 pm
Borg and beck is the design not the brand. And there's a lot of leeway within that
The other choice vs Borg and beck is a diaphragm clutch.
Loo it's of companies make Borg and beck style clutches. And alot of companies make diaphragm clutches.
PostPosted: Wed Apr 30, 2025 5:35 pm
Stan, Some company just built some good clutches for the slant 6 just a couple years ago. They made dual disc and everything. Cant remember who it was but Ryan got one so I can find it for you. Someone on here should remember who it was.
Just remembered- It was RAM. Call and ask them what they got! :D
PostPosted: Thu May 01, 2025 8:35 am
That ebay company sent me a 10 dollar off deal on the rad.
It was $100 dollars cheaper than the Champion one I looked up.
And Dan, that one you did is nice, but expensive when you had it done years ago.
Looks like I will be getting the Champion when they send me the mounting measurements.
Hard to understand why they don't have simple info on the web site?
As far as the clutch I have found a good used Weber 9 inch clutch for a good price.
Going to see how that feels, I have been told it had high pedal effort.
PostPosted: Thu May 01, 2025 2:09 pm
If it has a higher than stock pedal effort, you may want to consider torque shaft /z bar reinforcement to prevent failures later during use.
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
