| I need a Radiator and a Clutch, Recommendations? https://slantsix.org/forum/viewtopic.php?t=68185 |
| Author: | hyper_pak [ Wed Apr 30, 2025 8:35 am ] |
| Post subject: | I need a Radiator and a Clutch, Recommendations? |
I need both a Radiator and a Clutch. 1976 Dart, slant six. Radiator yoke pattern is 22 wide, 14 tall, bolt hole to bolt hole. Upper hose is center or left and left bottom. I need a clutch also. Brewer used to offer a package, but now you have to buy a flywheel with a GM pattern. I guess that is ok, but cost goes way up. I don't want a RockAuto replace every year unit. Ideas on either are welcome. Thanks! |
| Author: | Charrlie_S [ Wed Apr 30, 2025 8:44 am ] |
| Post subject: | Re: I need a Radiator and a Clutch, Recommendations? |
Check the dimensions. This might work for you. https://www.ebay.com/itm/403727821072?_ ... p_homepage |
| Author: | hyper_pak [ Wed Apr 30, 2025 10:33 am ] |
Thanks Charrlie that looks close. |
| Author: | volaredon [ Wed Apr 30, 2025 10:34 am ] |
RA usually has a few to pick from. I have never had a problem with LuK clutch which ive gotten several from them The one brand I have had problems with and their name is (for lack of a better way to put it) a lie.... That brand is "perfection"... In reality they're far from that. |
| Author: | Dart270 [ Wed Apr 30, 2025 11:36 am ] |
I like Champion radiators and they should have one for you. I bought one for my 68 Dart. Very high quality. Lou |
| Author: | hyper_pak [ Wed Apr 30, 2025 12:13 pm ] |
Rock Auto has a 10 inch clutch with a picture that says Bork and Beck.I have never had a problem with LuK clutch which ive gotten several from them The one brand I have had problems with and their name is (for lack of a better way to put it) a lie.... That brand is "perfection"... In reality they're far from that. That one could have springs added to make a serious clutch. If you get what they show. |
| Author: | hyper_pak [ Wed Apr 30, 2025 12:14 pm ] |
Thanks Lou, I will look at them.
Lou |
| Author: | Greg Ondayko [ Wed Apr 30, 2025 12:21 pm ] |
Check with Falcon Clutch https://www.falconauto.com/ I am sure he can build what you need. He resurfaced some pp's for me and refaced used / worn out clutch discs. Champion Radiator has a rad for your car. It will be AL and not look correct. Greg |
| Author: | SlantSixDan [ Wed Apr 30, 2025 1:49 pm ] |
Radiator, see here. This goes along with your stated philosophy of not wanting to buy junk. |
| Author: | volaredon [ Wed Apr 30, 2025 3:04 pm ] |
Rock Auto has a 10 inch clutch with a picture that says Bork and Beck.I have never had a problem with LuK clutch which ive gotten several from them The one brand I have had problems with and their name is (for lack of a better way to put it) a lie.... That brand is "perfection"... In reality they're far from that. That one could have springs added to make a serious clutch. If you get what they show. The other choice vs Borg and beck is a diaphragm clutch. Loo it's of companies make Borg and beck style clutches. And alot of companies make diaphragm clutches. |
| Author: | Rick Covalt [ Wed Apr 30, 2025 5:35 pm ] |
Stan, Some company just built some good clutches for the slant 6 just a couple years ago. They made dual disc and everything. Cant remember who it was but Ryan got one so I can find it for you. Someone on here should remember who it was. Just remembered- It was RAM. Call and ask them what they got! |
| Author: | hyper_pak [ Thu May 01, 2025 8:35 am ] |
That ebay company sent me a 10 dollar off deal on the rad. It was $100 dollars cheaper than the Champion one I looked up. And Dan, that one you did is nice, but expensive when you had it done years ago. Looks like I will be getting the Champion when they send me the mounting measurements. Hard to understand why they don't have simple info on the web site? As far as the clutch I have found a good used Weber 9 inch clutch for a good price. Going to see how that feels, I have been told it had high pedal effort. |
| Author: | Greg Ondayko [ Thu May 01, 2025 2:09 pm ] |
If it has a higher than stock pedal effort, you may want to consider torque shaft /z bar reinforcement to prevent failures later during use. Greg |
