| Would I make anybunny mad... https://slantsix.org/forum/viewtopic.php?t=68214 |
| Author: | Hunny Bunny [ Tue May 13, 2025 4:46 pm ] |
| Post subject: | Would I make anybunny mad... |
By proposing to take 2 slant sixes, flip them back-to-back and making a 450 CID V-12? I've been pondering this thought for a very long time. Now before everybunny rants at me how that can't be done, I do not actually mean to destroy 2 perfectly good slant six blocks. I would scan a block, make a CAD model that also incorporated all of the necessary changes [because, obviously flipping a block backward simply could never work anyhow], so that it could be bolted up to the same 727 or 4 speed bellhousings as any big block MOPAR would use, and it would, by default, have 2 separate cam shafts, but also, I would build some matching hemispherical combustion heads [because there ACTUALLY WAS ONE such hemi-[vertical]-six made by Chrysler at on point, as an experimental motor], and make an advanced alloy casting, including cross bolting. The really wide mains, with enough extra webbing material, and a custom forged 12 cylinder based crank could really be a lot of fun. Also, with HEMI heads, it would be a cross-flow head with the intake in the middle and the exhausts on each side. I'd begin with a 450 CID base model, and gradually engineer it up to at least 660 CID [kinda like a 440, only with a 50% more cylinders], possibly take it all the way to 1200 CID... Might even make an aluminum block version with aluminum heads and intake...with a blower-ready adapter... I wonder if people would like it, or hate it... ~( ,m,)~ |
| Author: | hyper_pak [ Tue May 13, 2025 5:42 pm ] |
| Post subject: | Re: Would I make anybunny mad... |
If you have the pocket change, go for it! |
| Author: | Charrlie_S [ Wed May 14, 2025 3:28 am ] |
If you are going to go to those extreams, why not go further? Legthen the block(s), use bigger bore/bore centers (allows bigger valves/ports), shorten stroke (more rpm). Or buy something like this https://www.sonnysracingengines.com/eng ... gas-engine It would probably be cheaper |
