| Main/rod bearings https://slantsix.org/forum/viewtopic.php?t=68267 |
| Author: | kesteb [ Fri Jun 27, 2025 11:17 am ] |
| Post subject: | Main/rod bearings |
Can you use big block main and rod bearings on a forged crank? |
| Author: | Greg Ondayko [ Fri Jun 27, 2025 12:36 pm ] |
| Post subject: | Re: Main/rod bearings |
Ceej Might know. Greg |
| Author: | Charrlie_S [ Fri Jun 27, 2025 2:29 pm ] |
No.
| Author: | kesteb [ Tue Jul 01, 2025 7:39 am ] |
OK, then can somebody suggest a good set of bearings that you can actually buy? |
| Author: | Rick Covalt [ Wed Jul 02, 2025 3:23 am ] |
King Bearings are very good. Summit and elsewhere |
| Author: | Will [ Wed Jul 02, 2025 4:51 am ] |
Calico Coatings They use your Mahle/Clevite number and put a high-performance coating on them. Will |
| Author: | Greg Ondayko [ Wed Jul 02, 2025 5:02 am ] |
I have used King bearings as well no issues with them. Greg |
| Author: | Charrlie_S [ Wed Jul 02, 2025 5:23 am ] |
I won the "door prize" at a King Bearings seminar at the PRI show, several years ago. It was for a full engine bearing set. I blew the moderators mind when he asked what engine I wanted the bearings for, and I said "a 66 chrysler 170 slant six". He wasn't even sure they had those available, and would have to check. I did receive them a few weeks later. |
| Author: | Dart270 [ Wed Jul 02, 2025 6:40 am ] |
I have used King bearings, and sometimes buy old stock clevite/michigan stuff off ebay, when it's cheap. Lou |
| Author: | kesteb [ Sun Jul 06, 2025 4:56 pm ] |
King bearings has a listing for the forged crank, but no price and they not available anywhere. Speed Pro has a listing on the NAPA site, but you need to call for availability, at least they have a price. The reason I asked about the big block bearing is because there is a thread on using big block caps. If you can use the caps, you should be able to use the bearings. At least in my thinking anyways. |
| Author: | Rick Covalt [ Mon Jul 07, 2025 3:09 am ] |
I just got King bearings at Summit a couple months back? And I just saw them last week at the parts warehouse called Falcon Sales. They have them and lots of other Slant 6 stuff. PS. They are listed on Ebay right now also. |
