It is currently Sun Oct 25, 2026 12:48 pm
 Post subject: Main/rod bearings
PostPosted: Fri Jun 27, 2025 11:17 am
Can you use big block main and rod bearings on a forged crank?
 Post subject: Re: Main/rod bearings
PostPosted: Fri Jun 27, 2025 12:36 pm
Ceej Might know.
PostPosted: Fri Jun 27, 2025 2:29 pm
No.
PostPosted: Tue Jul 01, 2025 7:39 am
OK, then can somebody suggest a good set of bearings that you can actually buy?
PostPosted: Wed Jul 02, 2025 3:23 am
King Bearings are very good. Summit and elsewhere
PostPosted: Wed Jul 02, 2025 4:51 am
Calico Coatings
They use your Mahle/Clevite number and put a high-performance coating on them.
Will
PostPosted: Wed Jul 02, 2025 5:02 am
I have used King bearings as well no issues with them.
PostPosted: Wed Jul 02, 2025 5:23 am
I won the "door prize" at a King Bearings seminar at the PRI show, several years ago. It was for a full engine bearing set. I blew the moderators mind when he asked what engine I wanted the bearings for, and I said "a 66 chrysler 170 slant six". He wasn't even sure they had those available, and would have to check. I did receive them a few weeks later.
PostPosted: Wed Jul 02, 2025 6:40 am
I have used King bearings, and sometimes buy old stock clevite/michigan stuff off ebay, when it's cheap.
PostPosted: Sun Jul 06, 2025 4:56 pm
King bearings has a listing for the forged crank, but no price and they not available anywhere. Speed Pro has a listing on the NAPA site, but you need to call for availability, at least they have a price.
The reason I asked about the big block bearing is because there is a thread on using big block caps. If you can use the caps, you should be able to use the bearings. At least in my thinking anyways.
PostPosted: Mon Jul 07, 2025 3:09 am
I just got King bearings at Summit a couple months back? And I just saw them last week at the parts warehouse called Falcon Sales. They have them and lots of other Slant 6 stuff.
PS. They are listed on Ebay right now also.
Users browsing this forum: Bing [Bot] and 5 guests
