| Any interest in an exhaust heat riser block off plate? https://slantsix.org/forum/viewtopic.php?t=68334 |
| Author: | MadScientistMatt [ Mon Aug 25, 2025 4:49 pm ] |
| Post subject: | Any interest in an exhaust heat riser block off plate? |
I'm using a Clifford intake manifold with a stock exhaust manifold in my turbo build. I originally used a 1/8" plate to block off the heat riser, but it warped. So I'm making a 1/4" thick version. Would anyone else want one of these plates? They'd be $20 or less if ordered in quantity. It won't fit any intake manifold that works with the stock exhaust manifold. |
| Author: | Greg Ondayko [ Wed Aug 27, 2025 5:48 am ] |
| Post subject: | Re: Any interest in an exhaust heat riser block off plate? |
Quote: It won't fit any intake manifold that works with the stock exhaust manifold. Shouldn't the exhaust block off fit on the exhaust manifold? Maybe you are saying that if you use this on the exhaust manifold you cant have a working Exhaust hotbox junction any longer to the intake manifold? In other words It will work with Clifford, Aussiespeed, Cain, Lynx, and Reproduction / Original Hyperpack, or other custom intakes with no exhaust heat provision. Greg |
| Author: | MadScientistMatt [ Wed Aug 27, 2025 4:51 pm ] |
Sorry if that was a bit confusing - this bolts to the exhaust manifold. I meant to say that you can't sandwich this in between an exhaust manifold and an intake that already bolts to the stock exhaust manifold, like a Super Six. For the Lynx, Hyper Pak, etc, you'd need to make sure you have at least a quarter inch between them and a stock exhaust manifold. |
| Author: | Rick Covalt [ Thu Aug 28, 2025 5:55 pm ] |
Quote: stainless steel bolt for future removal.
And never-seize |
| Author: | slantzilla [ Fri Aug 29, 2025 11:41 am ] |
Quote: Quote: stainless steel bolt for future removal.
And never-seize I had a couple of those plates that volaredon gave me. Not sure where he got them. |
| Author: | MadScientistMatt [ Sat Aug 30, 2025 4:14 am ] |
Placed an order for a few of them today and will have pictures of the installation when they arrive. |
| Author: | MadScientistMatt [ Sat Sep 27, 2025 1:50 pm ] |
Made an extra batch of them, and they're available for sale. https://cramerpower.com/products/slant- ... -off-plate Installation video: https://www.youtube.com/shorts/rILC94_j2ac |
