| 60-61 Valiant fuel tank filler tube "O" ring https://slantsix.org/forum/viewtopic.php?t=68335 |
| Author: | oldewrenchbender [ Thu Aug 28, 2025 10:53 am ] |
| Post subject: | 60-61 Valiant fuel tank filler tube "O" ring |
What size "O" ring for 61 Valiant fuel tank filler tube? Second question: Where to get the phenolic throttle carb. linkage insulator sleeve (or recommendation of alternative)? The car as I bought it has a piece of 1/2" rubber fuel hose where the phenolic sleeve is supposed to be. Thank you in advance. |
| Author: | Charrlie_S [ Thu Aug 28, 2025 12:14 pm ] |
| Post subject: | Re: 60-61 Valiant fuel tank filler tube "O" ring |
Can't help with the fuel filler gasket, but here is the carb linkage part https://www.ebay.com/itm/365720895782?m ... 62ef4f6ae2
| Author: | oldewrenchbender [ Thu Aug 28, 2025 3:54 pm ] |
Second question: Where to get the phenolic throttle carb. linkage insulator sleeve (or recommendation of alternative)? The car as I bought it has a piece of 1/2" rubber fuel hose where the phenolic sleeve is supposed to be. Thank you in advance. Bought it. I'll post the "O" ring size as soon as I dig out from hiding my Parker Hannifin "O" ring book and measuring cone. Though the original seems to be about 40 durometer rather than usual 60-70 as normal for Buna-N or Viton. Thanks again! |
| Author: | Charrlie_S [ Thu Aug 28, 2025 4:11 pm ] |
This might be the "O"-ring you need. https://www.detroitmuscletechnologies.c ... 8-1730087/ From the mopar 1961 parts manual the "O" ring is listed as illustration 14-86-83, and part number 2073 938 |
| Author: | Greg Ondayko [ Fri Aug 29, 2025 3:44 am ] |
If you cant find the 1961 specific o Ring, You might be able to get some info from Australasian sources. I bet that part is quite rare here unless you can find a viton or similar o ring with the same dimensions out of a gasket catalog or McMaster car or something of the like. Maybe SlantSixDan will have some insight into this as well. Other than a rebuilt or custom / hot rod fuel tank and sending unit there are not much support for the rear floor and gas tank stuff on the '60-'61 Valiants as they do not swap with the more reporoudced parts of the '62-'63 and up A bodies. Good Luck! Greg |
| Author: | oldewrenchbender [ Wed Sep 03, 2025 9:01 pm ] |
Thank you!I bet that part is quite rare here unless you can find a viton or similar o ring with the same dimensions out of a gasket catalog or McMaster car or something of the like. Maybe SlantSixDan will have some insight into this as well. Other than a rebuilt or custom / hot rod fuel tank and sending unit there are not much support for the rear floor and gas tank stuff on the '60-'61 Valiants as they do not swap with the more reporoudced parts of the '62-'63 and up A bodies. Good Luck! Greg Yes, I see the fuel filler tube "O" rings listed on an Australian website. Mcmaster.com certainly does have them once one knows the appropriate size; which is 2-327 (.210" cross section width x fractional ID: 1 3/4" x fractional OD: 2 1/8" [actual 1.725" 2.145"]. I went with Viton 75 durometer. As these are used in a static seal situation (ie: no reciprocating seal face relative motion) the Viton material should be a good choice. Buna - N certainly is okay also. |
| Author: | oldewrenchbender [ Wed Sep 03, 2025 9:04 pm ] |
I think you are correct. My vpn will not load the site but I would not find it surprising for Detroit Muscle Tech. to have them. From the mopar 1961 parts manual the "O" ring is listed as illustration 14-86-83, and part number 2073 938 Thank you. |
