T5 Help
https://slantsix.org/forum/viewtopic.php?t=68378
Page 1 of 1
Author:  Murch [ Sun Oct 05, 2025 3:29 am ]
Post subject:  T5 Help
Hey guys, I've been accumulating parts for the T5 swap over a few years and have gotten just about everything needed. Decided to go with a hydraulic clutch set up and will get that. Here's my dilemma...I ran into some physical problems and am not able to do it myself :(
I'm in between Chicago and Milwaukee, does anybody have suggestions on who I might be able to hire to do this? I'd really like to get it done as it's on my bucket list along with taking the Route 66 trip.
Author:  Greg Ondayko [ Mon Oct 06, 2025 6:40 am ]
Post subject:  Re: T5 Help
Well, if you are swapping to a Hydro Bearing, and reputable hot rod shop should be able to do this for you.
I cannot recommend anything your way.
It is also perfectly acceptable to stick with the Z bar and clutch fork when using the T5.
Author:  Murch [ Mon Oct 06, 2025 6:50 pm ]
Greg, first of all thank you for all your hard work on the T5 write up. The clutch isn't really a big deal. The cutting, welding, mounting etc... on the ground are. If I had a lift it would be easier but on the ground on stilts, just too much for me now. :(
Author:  Murch [ Mon Oct 06, 2025 6:53 pm ]
I'm sorry, re read my initial post, I have accumulated the needed parts but haven't done the work as of yet.
Author:  mcnoople [ Tue Oct 07, 2025 5:46 am ]
so you are looking for a reputable shop/person to do the actual install?
Author:  Murch [ Wed Oct 08, 2025 6:54 pm ]
Sorry for the delay.
Yes, I am.
I am ASE Certified, have been working on cars for 50 years and know many techs. But this is a specific type of modification that requires (in my opinion) more than your normal mechanic can handle. I thought I could handle it (knowledge and mechanical ability wouldn't be a problem) however I should have done it a few years ago instead of waiting. Had some issues that would now hinder me to do so.
Thanks
