| axle seals 62 valiant https://slantsix.org/forum/viewtopic.php?t=68399 |
| Author: | madmax/6 [ Wed Oct 22, 2025 1:34 pm ] |
| Post subject: | axle seals 62 valiant |
Does anyone have a part number for the CORRECT axle seals for a 62 valiant,,,orig 7 1/4 rear end. |
| Author: | Greg Ondayko [ Wed Oct 22, 2025 2:13 pm ] |
| Post subject: | Re: axle seals 62 valiant |
Does Rockauto List incorrect ones? I believe there are 2 versions of this seal. The later ones may be used with the large bolt pattern 7 1/4 on the fjm cars for example. I bet Dan or Charrlie can help. |
| Author: | SlantSixDan [ Wed Oct 22, 2025 7:32 pm ] |
'60-'62: one size of axle bearing and seal in the 7-1/4" rear axle '63-up: another size. Original P/N for the '60-'62 seal is 2070 130. That crosses to National 51256. I'm finding a lot of hits on both those numbers with a web search, and with an eBay search. I am not at all shocked if the ashes of what used to be the auto parts sector lists the '63-up parts for Valiants and Darts clear back to 1954, or just lists completely inapplicable parts for all Valiants and Darts from 1937 through 1991. |
| Author: | Greg Ondayko [ Thu Oct 23, 2025 3:54 am ] |
Thank you Dan. That listed seal is not in the RockAuto Listing for the '62 Valiant. There are 2 seals listed - one for Sure Grip and one without? I would not have imagined that the sure-grip option would have affected the Axle seal ID or Bore Ø. National 51256 is possibly just available as NOS - I cannot seem to find "new" versions of the seal. But as Dan says they are out there to buy. |
| Author: | madmax/6 [ Thu Oct 23, 2025 8:49 am ] |
Thank you,,,last time I went through this I ordered what was listed as correct and got the bigger incorrect parts.Trying to not go through this again. |
| Author: | SlantSixDan [ Thu Oct 23, 2025 10:08 am ] |
Quote: That listed seal is not in the RockAuto Listing for the '62 Valiant. Quote: last time I went through this I ordered what was listed as correct and got the bigger incorrect parts I am shocked. Shocked, I am. Just try to imagine all of my considerable shock and surprise.Quote: ]There are 2 seals listed - one for Sure Grip and one without? …which is a neat trick, given that Sure Grip was not available on that car.Quote: I would not have imagined that the sure-grip option would have affected the Axle seal ID or Bore Ø Quite correct, on cars that could actually have come with Sure-Grip, such as the '64-up A-bodies. So yeah, as I was saying about what remains of the auto parts sector.Quote: National 51256 is possibly just available as NOS - I cannot seem to find "new" versions of the seal. Here y'go, nice fresh brand-new seals. The price equates to $22.14/pair in US Dollars, but that's before postage and tariffs. Still, it might be worth it to eliminate the uncertainty of whether 50-60-year-old seals will still seal. And you'd probably be able to get a number off the new ones to buy them more locally next time. On the other-other hand, you might discover that they are a fine product of some joker in a dirt-floor Guangdong basement, thus differently iffy than the old-stock seals, but equally so.
| Author: | Greg Ondayko [ Thu Oct 23, 2025 11:04 am ] |
Quote: Quote: That listed seal is not in the RockAuto Listing for the '62 Valiant. Quote: last time I went through this I ordered what was listed as correct and got the bigger incorrect parts I am shocked. Shocked, I am. Just try to imagine all of my considerable shock and surprise.Quote: ]There are 2 seals listed - one for Sure Grip and one without? …which is a neat trick, given that Sure Grip was not available on that car.Quote: I would not have imagined that the sure-grip option would have affected the Axle seal ID or Bore Ø Quite correct, on cars that could actually have come with Sure-Grip, such as the '64-up A-bodies. So yeah, as I was saying about what remains of the auto parts sector.Quote: National 51256 is possibly just available as NOS - I cannot seem to find "new" versions of the seal. Here y'go, nice fresh brand-new seals. The price equates to $22.14/pair in US Dollars, but that's before postage and tariffs. Still, it might be worth it to eliminate the uncertainty of whether 50-60-year-old seals will still seal. And you'd probably be able to get a number off the new ones to buy them more locally next time. On the other-other hand, you might discover that they are a fine product of some joker in a dirt-floor Guangdong basement, thus differently iffy than the old-stock seals, but equally so.
Thanks, Dan! I suppose there is no Timken equivalent cross-reference to the national seal number. I also was unaware that the Sure grip was not available in a 7 1/4" axle until 1964. But it does confirm my observation of one in a 1964 Dart that Dad has had rotting away in the back of the shop since 1990 or so. Greg |
