More free parts: 170 and 225 cranks, stock coil, 904 converters, vlv cover, alternator, etc
https://slantsix.org/forum/viewtopic.php?t=68403
Author:  Dart270 [ Sun Oct 26, 2025 5:40 am ]
Post subject:  More free parts: 170 and 225 cranks, stock coil, 904 converters, vlv cover, alternator, etc
Hi Folks,
More free Slant 6 parts. Heavy stuff you need to arrange shipping or pick up. Light/small stuff I'll ship at your expense.
1) Core 170 Slant 6 crankshaft. Surface rust so needs turning. Small hub.
2) Core 225 Slant 6 crankshaft. Needs turning. Small hub.
3) 2800-3000 RPM high stall torque converter for 904. Tested and works great. Cracked pump drive hub so needs a new (alloy) one welded on by a professional.
4) Stock used 904 torque converters (at least 2).
5) Stock good used ignition coil.
6) Stock 70-up squareback alternator. Spins freely and I'm pretty sure it works since I kept it.
7) ~1965 stock valve cover with metal PCV fitting. Just needs cleaning up.
8) Stock cast iron alternator bracket (that bolts to head and block).
9) Stock 6.50-13 Goodyear spare tire on stock 13X4" rim. I think this has never been bolted on a car, and probably still has 1965 air in it... Excellent shape. Nice to hang on the wall?
10) Stock used brake pedal assembly from 64 Dart/Valiant. Good shape.
11) Stock 1968 1bbl iron intake. Nice condition with red paint, not much surface rust.
Let me know what you need/want. Thanks for the ad.
Author:  RumDungeon [ Sun Oct 26, 2025 9:19 am ]
Post subject:  Re: More free parts: 170 and 225 cranks, stock coil, 904 converters, vlv cover, alternator, etc
Pm sent on tq converter
