It is currently Sat Oct 24, 2026 4:50 am
PostPosted: Fri Nov 14, 2025 7:09 am
Please post here or PM me if you are interested in a set of aftermarket connecting rods designed to fit a CAST crank.
There was a group buy several years ago, but they have been sold out for quite some time.
It will take at least seven (7) sets with deposits for them to make another run of them. More details on estimated cost and deposit requirements coming shortly.
This is the email I just received from Marshall at Campbell Enterprises:
Good Day Rob,
I will get with Mr. Molnar and get back to you on estimated cost and required deposit amount. It is really tough to estimate future pricing now due to all the extra uncertainties that affect such things.
Specs will be:
H beam 7.005” long center to center
Fit stock 225 cast crank with 2.187” rod pin diameter
Fit stock .901” wrist pin diameter
Big end width .940” to fit cast crank rod pin width
Pin end width .980”
Weight approximately 605 grams
Molnar Proprietary 3/8” ARP2000 material bolts
