It is currently Thu Oct 22, 2026 5:14 am
 Post subject: Exhaust question
PostPosted: Wed Jun 06, 2007 11:13 am
Car Model: Valiant V200 225 4dr three on the tree
In the third "runner" of the exhaust is a "rod" or something, can I take it away without leaks.
Does anybody know what function it has?
Se pictures in the links:
http://dansby.net/slant/pictures/DSC00538.JPG
http://dansby.net/slant/pictures/DSC00539.JPG
http://dansby.net/slant/pictures/DSC00540.JPG
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Wed Jun 06, 2007 11:21 am
That's for the carburetor anti-ice system. It's not a rod, but a hollow sleeve. Steel lines would've been pushed into this sleeve from top and from bottom. The one from the top would've been insulated with woven silica/asbestos sleeving and would've connected to a threaded fitting on the passenger side of the carburetor base. The one from the bottom would've been uninsulated, and connected to a rubber hose which would've connected to a nipple on the underside of the air cleaner baseplate. This was optional equipment on Canadian-made \6 cars from 1960 through 1969, and was present on most of those cars. It was standard equipment on all 1969 US-market \6 cars. It seems quite logical to assume that cars destined for the Nordic countries would have the system, even if they were built in the US! :shock:
You can't remove the sleeve without causing very large exhaust leaks. It doesn't really get in the way.
PostPosted: Wed Jun 06, 2007 11:59 am
Ok, then I know.
Thanks for the info.
Lasse
Signet -66 225
MSD6A
A904
7 1/4 3.23
PostPosted: Thu Dec 04, 2008 5:00 pm
Where was this info when I was struggling with carb icing? Is there a specific port on the carb for this line to route to or is it a specific carb for the system? Sorry for the hi-jack, it seemed relevant.
 Post subject: 225 manifold
PostPosted: Mon Jan 14, 2013 2:31 pm
Then really it would be no big deal to tap and plug the 2holes, correct? Only warm weather driver.[/i]
PostPosted: Thu Jan 08, 2015 8:20 pm
(very tardy) Specific carbs for use with this system -- can't adapt it to a carb not originally equipped for it. Fine to leave the manifold heat pipe unused -- no benefit from tapping or plugging. On the other hand, if you have the anti-ice system (including carb) and you don't want/need it, it's fine to just run a hose directly from the air cleaner fitting to the carb fitting.
 Post subject: Re:
PostPosted: Thu Jan 22, 2026 2:21 pm
Just a FYI. I have a NOS exhaust manafold equiped like this on the shelf.
Users browsing this forum: DuckDuckGo [Bot] and 19 guests
