It is currently Fri Oct 23, 2026 2:15 pm
 Post subject: No spark 78 D100
PostPosted: Sat Jan 24, 2026 7:01 pm
Car Model: 1978 Dodge D100
No spark not sure the reason, Was driving battery stopped charging checked the alternator it was getting charge so I replaced the voltage regulator, It’s just cranking no spark checked with a spark tester on the plug wire. Now what should I check.
 Post subject: Re: No spark 78 D100
PostPosted: Sun Jan 25, 2026 9:51 am
Car Model: 1966 Dodge Dart
Is this a Lean Burn, regular Mopar electronic ignition, or something non-stock/aftermarket? If it's a conventional Mopar ignition and you have a voltmeter, I have a list of what to check here:
Testing Mopar electronic ignitions
Matt Cramer
PostPosted: Tue Jan 27, 2026 11:53 am
That doesn't compute.If the alternator was charging, then the reg would be good (unless overcharging). How did you determine the alternator was charging, if the engine was not running? Even if the alternator/charging system was bad (not functioning) as long as the battery had enough voltage to crank the engine, the charging system is not what caused loss of spark.
Do you have a wiring diagram for the vehicle? If you do, post back, and we can walk you through testing steps. Also as Mat asked, we need to know what system you have. Stock, or not, and if not stock, what it is.
PostPosted: Tue Jan 27, 2026 12:41 pm
78 truck wouldn't be lean burn yet.
Users browsing this forum: Ahrefs [Bot] and 24 guests
