| Offset dowel pins https://slantsix.org/forum/viewtopic.php?t=68536 |
| Author: | Rick Covalt [ Fri Feb 13, 2026 12:40 pm ] |
| Post subject: | Offset dowel pins |
I rechecked my blowproof bellhousing offset and it looks like I could move it about .005". But .007 is about the lowest that I see. And measuring my pins it looks like they are .496" not .500 like most companies are selling. Has anyone used these .500 pins or do I call Brewers ( Only place I seen the correct .496" pins) Or if you got them somewhere else let me know. When all is said and done I am going to be going from .005 offset to .002 or .003" Still not at all sure it is worth the extra work and time for .003" |
| Author: | hyper_pak [ Fri Feb 13, 2026 4:18 pm ] |
| Post subject: | Re: Offset dowel pins |
I did see a post somewhere someone drove those pins in and cracked a block. Are the pins you have marked Ford? |
| Author: | Greg Ondayko [ Fri Feb 13, 2026 7:33 pm ] |
Check the service manual or call Brewers for what a TIR reading should be.You are going to be pretty close with what you have I'd say. I have futz'ed with the 0.500" dowels It is not worth it. Get the correct ones from Brewers or get some here: https://www.robbmcperformance.com/products/dowels.html I have bought a set from robbmc before. Good pieces. Summit might have the correct mopar ones as well? |
| Author: | Rick Covalt [ Sat Feb 14, 2026 5:13 am ] |
I did not get any offset pins yet. FSM supposedly says .008 total is fine. First time I checked it I was at .008 total runout (.004 off centerline), the second time I had .010. (.005 off centerline). So it appears at most I am .001" off spec. I am going to send it and hope for the best. Thanks guys! |
| Author: | Dart270 [ Sat Feb 14, 2026 12:21 pm ] |
I bet you will be just fine, Rick. Yes, you need the Mopar spec 0.496" pins. They are 0.007" offset, IIRC, for the smallest pin. MP used to sell them. Lou |
