| Any tricks to changing the key cylinder in the ignition switch? 1966 Dart https://slantsix.org/forum/viewtopic.php?t=68543 |
| Author: | MadScientistMatt [ Mon Feb 16, 2026 3:48 am ] |
| Post subject: | Any tricks to changing the key cylinder in the ignition switch? 1966 Dart |
I have an ignition switch with intermittent contact on the IG2 terminal. I have a used spare, but no key to that one. So I thought I'd swap cylinders. There is a button that looks like it should release the cylinder, but the cylinder won't pull out. Is there any trick to this? Or should I just order a new switch and new cylinder? Are new replacements decent quality? |
| Author: | MadScientistMatt [ Mon Feb 16, 2026 5:19 am ] |
| Post subject: | Re: Any tricks to changing the key cylinder in the ignition switch? 1966 Dart |
Solved - got to put the key in and turn it to the run position. Which means if I use the spare, I'll need to drill out the release tab since I don't have its key. Or I may just order a new one. |
| Author: | GTS225 [ Mon Feb 16, 2026 6:01 am ] |
Any decent locksmith worth the title should be able to rekey what you have. Roger |
| Author: | MadScientistMatt [ Mon Feb 16, 2026 6:31 am ] |
True, but I'm not sure it's worth the money to use a 60 year old ignition switch. I just ordered a new one. |
