| IS THERE any in general mopar 5v gauge replacements movements?? https://slantsix.org/forum/viewtopic.php?t=68583 |
| Author: | whizzer333 [ Sun Mar 29, 2026 11:06 pm ] |
| Post subject: | IS THERE any in general mopar 5v gauge replacements movements?? |
Just wondering if anyone know of companies that make replacement 5V dash gauges for mopar in general. I've seen reproduction gauges for limited or certain models. HAS anyone made mopar 5V gauge replacements in general where you can use original gauge face plate?? Thanks |
| Author: | SlantSixDan [ Mon Mar 30, 2026 12:20 pm ] |
| Post subject: | Re: IS THERE any in general mopar 5v gauge replacements movements?? |
No. What specific problems are you having, and with which gauges? |
| Author: | whizzer333 [ Mon Mar 30, 2026 3:09 pm ] |
Need replacement 5v gauge movements. |
| Author: | SlantSixDan [ Mon Mar 30, 2026 6:54 pm ] |
Guess you're outta luck, then. If you'd provided the requested information, you might've got a useful answer. Oh, well! ¯\_(ツ)_/¯ |
| Author: | mcnoople [ Tue Mar 31, 2026 5:54 am ] |
If you are willing to spend big money there is a company named "new vintage gauges" that will make any gauge that you design. You could have brand new gauges designed to fit brand new bezels that will fit within your original cluster that don't use the original 5v wiring/regulator. You would have to work with them, and they would likely need your cluster/bezel for precision measurements AND it would not be cheap. I've seen reproduction gauges for limited or certain models. HAS anyone made mopar 5V gauge replacements in general where you can use original gauge face plate?? Thanks Of course since it is aftermarket you are at the mercy of that company for any future replacement parts that may fail. They may be willing to attach and calibrate their equipment to a faceplate/bezel that you supply. I have never used the company and am not endorsing them, but they have been around for at least 10 years and claim to be US produced instead of mystery 3rd world factories in an unknown country. here is the linky https://newvintageusallc.mybigcommerce.com/ |
| Author: | whizzer333 [ Wed Apr 01, 2026 5:03 am ] |
Thanks for reply. I'll look into it. NOS replacement parts are rare and expensive online. Small batch and custom work, big fan of supporting businesses that make parts for classic cars At some point with no replacements, better than rigging something else in general. Need a fuel gauge for a 62 Lancer. |
| Author: | whizzer333 [ Wed Apr 08, 2026 9:51 am ] |
I got thru to new vintage on the phone. They don't make or custom fabrication for 5v mopar gauges. All gauges 12v only. All small gauges are industry standard 2" or 2 1/16" gauges. Making these any any aftermarket will probably involve removing gauge housing and making terminal contacts shorter to fit in OEM DAS Wbezel cover. It's a shame no company made a batch run of mopar 5V movements for gauge replacements using your old faceplate for original look. WHY hasn't any of the restoration companies thought of this???? |
| Author: | SlantSixDan [ Wed Apr 08, 2026 11:32 am ] |
Probably because you're still insisting on asking the wrong question, and actively refusing the help you need because it's not the answer you think you want to the question you insist on asking. |
| Author: | mcnoople [ Wed Apr 08, 2026 1:31 pm ] |
When I posted the link to newvintage I clearly stated that their gauges would not use the mopar 5v system. It would be fitting their equipment to your bezel. With enough money spent they could make pieces that would fit in the spots you have available, BUT it would be modern gauges calibrated to the matched modern sending units, NOT vintage mopar 5v stuff. I will try to translate what Dan has posted, he is one of the most knowledgeable people you will ever find on any forum that he frequents and you seem to have tickled his nerves some. What is the problem you are having with your fuel gauge. What are its symptoms? What troubleshooting have you done? What parts have already been replaced? What other modifications have been done to the car? The mopar 5v gauges are fairly reliable but do have age and common issues working against them. Your problem could be something as simple as a missing/rusted piece of metal that you wouldn't know to look for under the car. The gauges themselves can be tested individually and there are threads on here on how to do that. Replacing old parts on car is nearly impossible these days because quality control (on parts such as fuel sending units) is nonexistent. If you start replacing parts without first proving those parts are actually bad you may create more problems that will waste time and money. |
| Author: | MDchanic [ Wed Apr 08, 2026 1:50 pm ] |
MoPar #2257925 (if I read my parts manual correctly).eBay link to 2 of them on sale right now, NOS $150 to $270. You won't get a custom-made gauge cheaper. Or just put up a Want ad for a used one. - Eric |
| Author: | SlantSixDan [ Wed Apr 08, 2026 8:39 pm ] |
I will try to translate what Dan has posted, What is the problem you are having with your fuel gauge. What are its symptoms? What troubleshooting have you done? What parts have already been replaced? What other modifications have been done to the car?
See also here
| Author: | whizzer333 [ Fri Apr 10, 2026 11:00 am ] |
Thanks for the replies and help. It's a 62 lancer fuel gauge that's bad and not functional . I'll contact the company to see what best substitute they can do. The only real advantage of going with that company over other aftermarket parts that are cheaper, if they can match the size and depth , bolt pattern of OEM gauge mounting . This would eliminate the need to adapt and make a custom mount for a standard 2" to 2"/16 instrument aftermarket gauge. Ideally something made to mount directly to OEM PCB would be best for meter centering. Gotta call them.. Custom gauges would be better as old ones are slimmer and smaller than industry standard gauges. They may need to remove or have meters made without those round bulky housings that original gause don't have. Unless I talked to the wrong person Turbo Slant 6, they only do 12v gauges.. The info has been most helpful. Thanks... |
| Author: | MDchanic [ Fri Apr 10, 2026 1:51 pm ] |
Okay, at the risk of being drawn into the maelstrom, which I swore I wouldn't do: It is very unclear why you are trying to buy a custom gauge. What is wrong with just buying a used gauge? Dan would probably be able to quote you chapter and verse, but, in general, even if the exact gauge is hard to find, the mechanisms of gauges from different years and models are likely to be the same, even if the needles or faces are stamped or printed differently. – Eric |
| Author: | whizzer333 [ Sun Apr 12, 2026 2:36 am ] |
The original gauges are quite rare and expensive due to age. The mechanism or movement I was referring to was 5v OEM. I'm just surprised no meter movements were made in general for 5v where you swapped out the faceplate. Not ideal, but would let you do some type of repair or refurbish one. Not engineering some cross compatibility or substitutes for parts for generations of models just leaves you with original factory run of spare parts. After that sounds like your Sh"t outt! L'ck Kinda surprised can't find since mopar used these for a couple of decades.. If anyone has a good one for sale in this forum let me know. |
| Author: | whizzer333 [ Thu May 14, 2026 9:41 pm ] |
So I lucked out a found an EXCELLENT 12v meter replacement. I know not ideal but works on 12v. Electromechanical gauge with a calibration adjustment. Had to remove bulky 2" round industry standard housing to make new meter similar to original gauge in size. Had to shorten contact terminals also. The calibration adjustment didn't know about til housing removed. New gauge originally showed low deflection with a lot of fuel in tank. So connected gauge modified with no round cover housing to 12v and ground to simulate high tank leveland adjuster calibration for full meter deflection. Connecting ground contact back to sending unit clearly shows sending unit working perfectly and shows difference in restance!!!! The appearance of meter is close to stock. I probably should of calibrated meter to slightly above full to compensate for low resistance at full. Close enough for now and stock looking appearance. My single barrel Carter carb sips fuel with better exhaust and has NICE throttle response. |
