A pic would help-- grounding braid from engine to firewall
https://slantsix.org/forum/viewtopic.php?t=68594
Page 1 of 1
Author:  whizzer333 [ Mon Apr 06, 2026 1:57 am ]
Post subject:  A pic would help-- grounding braid from engine to firewall
Anyone got a picture of a 62 Lancers grounding braid from the engine to the firewall. A picture would be useful to see stock location of connections.
Thanks..
Author:  hyper_pak [ Tue Apr 07, 2026 5:48 pm ]
Post subject:  Re: A pic would help-- grounding braid from engine to firewall
It's not stock, because I made my own ground.
But it is a 62 Lancer.
I just picked up one bellhousing bolt.
Author:  whizzer333 [ Wed Apr 08, 2026 9:22 am ]
Thanks hyperpak,
Found it. Thought I saw it before. Your car is sooooo clean. Mine is such a relic. I'm keeping it that way so people don't look at it too much. The main ground connection from battery to engine block showed the engine contact somewhat rusty also. I also made my own engine to firewall replacement cable soldering the big wires to the connection terminal for a sure contact. All monting surfaces were sanded til smooth and shiny.This solved a partial or poor charging issue. I got the car because a collector couldn't figure out the charging problem . Car ran fine but with headlights on showed unusual strain on electric system . A lot of work as car was not in a protected environment. A car cover goes a long way to protect classic cars from dirt, rain and bird droppings. My car cover worth every penny I paid for it.
File comment: Firewall cable
Author:  hyper_pak [ Mon Apr 13, 2026 8:09 am ]
Thanks hyperpak,
Extra gounds won't hurt either.
Good luck with your project!
