| 1965 Z-Bar (or something that will work) https://slantsix.org/forum/viewtopic.php?t=68628 |
| Author: | Greg Ondayko [ Sat May 02, 2026 3:43 pm ] |
| Post subject: | Re: 1965 Z-Bar (or something that will work) |
Almost all of the Pre-1967 bars will have that same shear failure The Tube diameter was made thicker after 1967? All of my (stick) A and F body cars have had this same failure. I am not sure if brewers has the correct one for your car. I buy them at swap meets and slice and dice them to fit my cars. I can Repair and reinforce them as well. I have done this on the thinwall tube for my '62 wagon. The link above does not show my upgrade for the '62 valiant, but I wrap and reinforce the thin tube at the failure point and then re weld the arm on. Best of Luck, Greg Good luck, Greg |
| Author: | Aaron65 [ Sat May 02, 2026 4:34 pm ] |
Thanks Greg. What do you use to wrap your thinwall tubes with? Of course, it might be worth shopping for a later unit and cutting it apart like you did. |
| Author: | Greg Ondayko [ Sat May 02, 2026 6:57 pm ] |
More tube from the scrap bin.
| Author: | Aaron65 [ Sat May 23, 2026 11:41 am ] | ||||
| Post subject: | Re: 1965 Z-Bar (or something that will work) | ||||
Brewer's had a nice 7.6" tube for $45 shipped that is far thicker than the original. I used the old one as a template, cut the arms off, and rewelded them using my old flux core MIG welder (the welds are ugly, but I saw signs of heat on the inside of the tube). Unfortunately, my new LUX pressure plate seems to be making a springy, popping noise, so I may just throw in the old pressure plate when I feel like taking a day to do the same job twice.
| Author: | nkeehaul [ Mon Jul 06, 2026 6:57 am ] |
Hey |
