It is currently Sat Sep 12, 2026 8:41 pm
PostPosted: Mon Sep 07, 2026 9:41 am
Car Model: 1964 Plymouth Valiant
The housing clamp bolt for the park lock cable insert won't tigten. Is it likely the housing threads inside are stripped or the bolt is stripped. Can the bolt be removed or does the park lock cover have to be replaced. If so where can I find the cover. Thanks.
