It is currently Tue Jun 02, 2026 3:16 pm
PostPosted: Sun May 31, 2026 5:48 pm
Car Model: 1962 Dodge Lancer
Low mile survivor, completely refreshed and ready for cruising season. Registered and insured driver ready for a new owner.
This particular Lancer was owned by the same family in Ohio from 1962-2004, where it spent much of its life in a garage not being driven. It still wears its original paint, interior and only has 35,000 miles on the car. I have owned it since 2025 buying it from the second owner and it has undergone a series of upgrades including disc brakes, new wheels, suspension, and engine replacement.
Engine:
Less than 2,000 miles on rebuild
225 rebuilt with shaved head, port polish, hardened seats, new valve train
252 cam
Super Six Conversion
NOS Holley 2280 Carb
Fuel line mod
NGK extended reach plugs
Full 2.5” mandrel bent exhaust
Mopar electronic distributor
HEI conversion
Road tube converted to pcv
Upgraded radiator
7 blade cooling fan
High flow oil pump
Suspension & Drivetrain:
Rebuilt front end
Boxed lower control arms
New ball joints, HD tie rods, strut rods
Spax Shocks
Brakes Wheels
SBP disc from Scarebird
9” Rear Drums(will be new/rebuilt)
Mopar Performance dual master cylinder
Wilwood brake proportioning valve
All new steel lines and soft lines
14” steel wheels/caps from 68 Dart
Additional changes:
New Carpet
Sound Deadening
Closed Cell Foam
Oil pressure gauge
Tachometer
3rd brake light
DRL and running lights
LED bulb upgrades
Headlight converted to Hella with relay
@crackedback battery cables/alt wire around
Powermaster 1 wire alternator
Recent maintenance:
New Fuel Pump
Spark Plugs and Wires
Oil Change
Brake fluid flush
Tires
$11,500 cash located in Woodland CA 95695 can assist with shipping, my house is accessible to large trucks.
Pics on FABO:
https://www.forabodiesonly.com/mopar/th ... or.600006/
Video of the cold start on Facebook:
https://www.facebook.com/marketplace/it ... tid=wwXIfr
