| Power steering for my 1961 Plymouth Valiant https://slantsix.org/forum/viewtopic.php?t=68693 |
| Author: | crickhollow [ Tue Jul 07, 2026 4:18 am ] |
| Post subject: | Power steering for my 1961 Plymouth Valiant |
Can I fit power steering to my 1961 Plymouth Valiant? |
| Author: | hyper_pak [ Tue Jul 07, 2026 7:32 am ] |
| Post subject: | Re: Power steering for my 1961 Plymouth Valiant |
From what I understand, the answer is yes. They made a high mount drivers side alternator mount from the t-stat housing. The pump mounted below. Shimos has installed it on his Valiant Wagon. |
| Author: | SlantSixDan [ Tue Jul 07, 2026 4:55 pm ] |
High-mount alternator etc is '60-only, when the alternator was on the manifold side. For '61, it was moved to the distributor side. P/S pump bracketry is '60-'66; get the brackets to go with the kind of pump you're using; OE was Thompson (--> TRW, later Federal pumps also fit these brackets), with Saginaw pumps (different bracketry) being added in parallel starting in '65. Later brackets put the P/S pump too far out from the engine for sure compatibility with narrow early engine bay, though that problem is more likely with A/C. Make sure to get brackets and a pump (or at least a pump pulley) from a car without factory A/C. The power steering gearbox is '60-'61 Valiant-Lancer only; no other years or models. That'll be difficult to find, and you'll almost certainly have to send it to Red Head or Steer & Gear or Firm Feel for rebuild (and upgrade, if you're wise). High-pressure hose (from pump to box) is still available, last I checked. Steering shaft is shorter with P/S, and it's another '60-'61-only piece; you may wind up having to get your existing shaft shortened. P/S pump drive sheave bolts onto the front of the vibration damper. Same all years, right from '60 to '87. |
| Author: | Dart270 [ Tue Aug 18, 2026 2:14 pm ] |
Just say no to power steering... These cars do great with manual, IMHO, and the road feel and handling are so much better. Lou |
| Author: | SlantSixDan [ Tue Aug 18, 2026 4:53 pm ] |
Honestly, yeah. I can see wanting a faster ratio (fewer turns lock-to-lock) on a '62-up car, because those have a 24:1 ratio with 5-3/4 turns lock to lock. But they are a joy to drive with a 20:1 nonpower box installed. 4-1/2 turns lock-to-lock. The '60-'61 cars with nonpower steering all came with 20:1. Power steer is 16:1 (3-1/2 turns) but it comes at a pretty giant cost: no roadfeel and not enough self-centre action unless you spend for a super-premium built-up box, much heavier, hassle of a more crowded engine bay and another belt (with a not-very-well-designed belt drive), new leak points, a new parasitic drain on engine power… |
| Author: | Greg Ondayko [ Wed Aug 19, 2026 3:44 am ] |
My other stock '62 is a breeze to drive with the non-power steering. Of course, it has the Mopar 24:1 Steering Box. The 20:1 would be ideal, but for me, I would likely toss in a 16:1 box to fit my personal taste. |
| Author: | SlantSixDan [ Wed Aug 19, 2026 11:13 am ] |
I hated the 16:1 nonpower box I put in my '65 (with aluminum 225 engine, for reckoning of how much the front end weighed). Sapped all the joy and fun out of driving the car, it did. |
| Author: | Greg Ondayko [ Wed Aug 19, 2026 6:38 pm ] |
Not for me though. It zapped some fun into my '64! Everyone is different. And I can save $3 by not needing that gym membership becasue ...you know parking and garaging a car with a 16:1 manual box. |
| Author: | Dbarnes [ Thu Oct 22, 2026 10:39 am ] |
I know this post is old, and not sure if it would fit your application.. But I used an 80's D150 low mounting power steering pump, then turned the smog pump mount into a driver's side alternator mount for this build.. https://photos.app.goo.gl/4gvNRZu6jo9VP6NT8 |
