It is currently Fri Oct 09, 2026 6:33 pm
PostPosted: Tue Sep 08, 2026 5:02 pm
68 Barracuda Fastback for sale
$15500
I am willing to consider reasonable offers, but I do not need to sell the car, I still have the garage space, I can still drive it.
I just don't drive it much. Time moves on and it may be time to move this car on to someone who would use and enjoy it.
The car is in Greenville OH. Greenville is about 45 minutes north of Dayton OH.
This is a driving-running street-strip-autocross ready car.
Built Slant Six, the engine started as an 87 truck engine.
MPFI with MS3 Pro ECU
KB 2.2L pistons
K1 Rods
Oregon Cam Grind #1456 254/258 @.050 .560 lift
crank scraper and windage tray
roller rockers
B3 rocker stands
Ford 289 valves
beehive springs
fully ported head with port flow data
904 transmission built by A&A Transmissions Camby IN
B&M Ratchet Shifter
8.75 rear
742 center section
3:55 gear set
Sure Grip
ESPO rear springs
Front suspension rebuilt, problem solver bushings, C Body tie rod ends
340 torsion bars
Hotchkis front sway bars
Hotchkis sub frame connectors
Bilstein shocks
4wheel Disk brakes
Front 73 and up Mopar
Rear Dr Diff.
new hand brake cables
AMD rear quarters, trunk and trunk extensions and rear floor and front inner fenders professionally installed
Fiberglass hood, front bumper, lightweight front bumper brackets
Classic Air Conditioning
Rally Dash with working tach
Deadenbear Delay box
Procar Elite seats
OE Factory tinted windows
New Carpet
4 speed pedals and 4 speed hump
Mopar Tuff Wheel with the correct spacer
New Legendary door panels, in box not installed
New OER chrome outside door handles in box not installed
all the original OE front 1968 headlight grills and bezels are included.
No OE bodywork was modified, easy reinstall.
OE metal hood, latch and springs are included
OE front bumper and brackets are included
OE rear seat and brackets are included
thanks for looking, I will post additional photos below.
PostPosted: Tue Sep 08, 2026 5:07 pm
additional photos
PostPosted: Tue Sep 08, 2026 5:09 pm
additional photos
PostPosted: Tue Sep 08, 2026 5:17 pm
certainly not a perfect car
Front fenders are OE, basically solid but have repairable rust where they mount to the inner fenders and at the lower rear corners. Fender mounting bolts are new
Door are solid and shut tight, they do have repairable rust on the lower edge seam.
Light shipping damage on left and right side rear quarters as shown in photo
PostPosted: Tue Sep 08, 2026 5:21 pm
a build thread
https://slantsix.org/forum/viewtopic.php?t=61820
PostPosted: Fri Sep 11, 2026 7:00 am
I could not be happier! The 68B is going to a Great Guy here at .org
The actual change of possession is about a month away, but the deal is done.
Personally, I still have and drive the 1983 D150, so I will still be around the Slant Six world.
Regards
John
PostPosted: Fri Sep 11, 2026 3:36 pm
That is a great car for someone John! Glad you got it sold quickly.
PostPosted: Fri Sep 11, 2026 3:42 pm
That was quick
A couple of weeks ago you were just thinking about selling...
