It is currently Thu Oct 22, 2026 4:21 am
PostPosted: Tue Sep 08, 2026 3:14 pm
Car Model: 1981 Dodge D150 and Jeep ratrod with Slant/727
So I think my hydraulic slant might have starved for oil on the top end and chewed up my rockers and the tips of the valves. I bought 11 old stock Perfect Circle ones on Ebay, still in the boxes. But they have what appears to be a manufacturing defect, the oil passages out to the ends of the rocker tip are poorly formed or crushed. Some of them are completely blocked, and some of them have a very restricted oil passage.. Its not a big deal, the seller has offered to refund any that are unusable.. I was just wondering if anyone on here has run into these before? Perfect Circle used to be good stuff, but I guess anyone can have a bad run of parts..
https://photos.app.goo.gl/sgb32nC2ugehVytg7
PostPosted: Tue Sep 08, 2026 5:30 pm
a while back, maybe 2013 I had purchased a set of NOS Mopar hydraulic slant six rockers from Mancini Racing.
After about 100 miles one of the rockers failed, completely separated at the weld joint. Looking at it I could see there was minimal weld penetration at the spot welds. IIRC the Mopar boxes had a manufacturing date of 1998,, I found it humorous that defective part sat on a shelf for fifteen years waiting for me to buy and install it.
PostPosted: Wed Sep 09, 2026 9:29 am
Its hard to see in the pictures, looks like the passage going to the tip is smashed.
I just had a set of solid rockers with the valve passages completely blocked with crud.
Could not clean them.
PostPosted: Thu Sep 10, 2026 7:50 am
Oddly enough, when most of these Perfect Circle ones turned out to be defective, I ordered 5 NOS Mopar ones on Ebay.. And one of those 5 is defective like that, on the valve end the two halves aren't fully welded together, leaving a split in the middle of the wear surface. The seller is sending me another one..
https://photos.app.goo.gl/dbtjyjVb6X8NwQdW6
Users browsing this forum: Amazon [Bot] and 12 guests
