| engine https://slantsix.org/forum/viewtopic.php?t=68780 |
| Author: | 66darter [ Fri Oct 09, 2026 7:54 am ] |
| Post subject: | engine |
I am looking to get more HP from my 1966 170 engine. currently have sequential fuel injection, oversized valves in a super 6 port matched head. A racer brown CCS -190 cam (duration 190 degrees@050,107 degrees lobe separation). the exhaust is a stock manifold with 2.25 inch exhaust all the way out. Would a dutra exhaust manifolds make a noticeable improvement? Not sure what my current compression ratio is. I would like it to be 9-9.5. I just had it dynotuned and rwhp was only 85. The injection is a megasquirt ms3. |
| Author: | Charrlie_S [ Fri Oct 09, 2026 8:27 am ] |
| Post subject: | Re: engine |
Did you measure the combustion chambe volumm? If not, When the head work was done, was the head milled? I would start by dong a compression check, to make sure the engine is in good "basic" condition. |
| Author: | 66darter [ Fri Oct 09, 2026 8:28 am ] |
yes head was milled not sure how much |
| Author: | Charrlie_S [ Fri Oct 09, 2026 8:33 am ] |
send me a PM and I will give you my phone number. We can talk. Charlie |
| Author: | Rick Covalt [ Fri Oct 09, 2026 9:38 am ] |
A 190 degree @ .050 is only @ 4 degrees longer than a stock camshaft so that is pretty small. |
| Author: | Dart270 [ Fri Oct 09, 2026 12:47 pm ] |
Yep, that is a stock cam. Please say what is your induction too - intake, carb, tuning on that? Lou |
