| FOUND Looking for a free or cheap rebuilt or known good 225 head in the Los Angeles Area https://slantsix.org/forum/viewtopic.php?t=68782 |
| Author: | volaredon [ Sat Oct 10, 2026 6:59 pm ] |
| Post subject: | Re: Looking for a free or cheap rebuilt or known good 225 head loosely in the Los Angeles Area |
There's a guy on FABO (I believe it's user "junkyard hero") offering a /6 for free over there but I believe you have to take the whole engine. He's somewhere in California... If I remember Ventura maybe? I have a fresh ready to run head here but I'm in IL. and have more tied up into it than you're suggesting. I have a bare head I could offer for free but shipping would cost more than your $50. Look around. They're out there. |
| Author: | Zane [ Sat Oct 10, 2026 8:41 pm ] |
Thanks for the offer and the potential lead volaredon. Unfortunately, I'm not seeing junkyardhero's slant posting that you're mentioning. If you see it again and are able to link it, that would be terrific, his account is indeed, LA based, and he has a killer brown dart wagon which I envy. However, if you're thinking of kerndog's post, then that is indeed a whole free slant but sadly it's at the other end of California outside of Sacramento (about 7 hours away) and he doesn't know if it runs. I'll keep looking around my area for now. Thank you again for the reply. |
| Author: | Dart270 [ Sun Oct 11, 2026 4:41 am ] |
With that compression, it should have started. Likely you have other troubles too. Check for a skipped/loose timing chain, ignition timing, carb/fuel. I imagine you checked the timing and fuel already... Lou |
| Author: | Wiloo [ Fri Nov 27, 2026 9:38 am ] |
| Post subject: | Re: FOUND Looking for a free or cheap rebuilt or known good 225 head in the Los Angeles Area |
Concernant le problème que j'ai eu avec le code P2181 sur ma Jeep Liberty, j'ai essayé de nettoyer les bornes de contact sans succès. J'ai ensuite vérifié le fusible associé, qui était effectivement défectueux. |
| Author: | Wiloo [ Fri Nov 27, 2026 9:41 am ] |
J'ai constaté P2181 et P3081 sur ma Slant Six récemment, symptômes similaires à ceux décrits. J'ai fait un reset du module de contrôle électronique, sans succès. La voiture ne démarre toujours pas correctement. |
