It is currently Fri Nov 20, 2026 6:45 pm
 Post subject: Got disc?
PostPosted: Thu Sep 18, 2003 8:17 pm
Found a 70's Scamp in the JY today with disc brakes. For all you Los Angeles s\anters its at the Wilmington Ecology yard. Get them while you can!
PostPosted: Fri Sep 19, 2003 10:31 am
Anything else of interest there? Haven't checked that yard out for a couple of years now, should go down tomorrow and snag those disc...Dave
PostPosted: Fri Sep 19, 2003 12:06 pm
What year exactly? (Are they 4 piston?)
 Post subject: Time to take a drive
PostPosted: Fri Sep 19, 2003 12:44 pm
Do know they would be a small bolt pattern. Hey, Dart 68 there is a mom and pop operated yard just as you get off the 405 and do the loop to loop onto Alameda on the left hand side, He's holding some parts for me, and from there it's a short trip to the Wilmington yard. Thanks for the heads up, otherwise I wouldn't make the 3 mile detour...Dave
PostPosted: Fri Sep 19, 2003 9:52 pm
It would have to be a mid 70's model. I scored myself another set of three point seat belts out of it. It has a 7 1/4 rear, a cracked plastic glove box liner, and single piston calipers. So I guess it would be a mid 70's model.
 Post subject: Always pull....
PostPosted: Fri Sep 19, 2003 10:41 pm
Disk brake setups are getting to be a premium, if I spot them I always try to grab the UCA's and the spindles, you can easily put them up for sale on this board or other mopar boards and pay for your junkyard scavenging trip...
FYI
