It is currently Wed May 06, 2026 7:13 am
 Post subject: transmission differances
PostPosted: Sat Oct 11, 2003 7:02 pm
Can any one tell me how to tell the differance between a 904 and a 727 transmisson?
PostPosted: Sat Oct 11, 2003 7:52 pm
i think it is cast on it what did it come off of
PostPosted: Sat Oct 11, 2003 9:39 pm
The 904 oil pan is squarish shape with one beveled corner.
The 727 oil pan is squarish shape with one beveled corner and a lump on another corner.
PostPosted: Sun Oct 12, 2003 7:04 am
So, I have a 727 is it fairly easy to rebuild? I've never rebuilt a trans. But I'm willing to try, so I can maybe save a few bucks. By the way it came out of my 77' aspen.
PostPosted: Sun Oct 12, 2003 9:18 am
if it has a slant six and it is orignal it is more than likeiy 904 i think 727 went in slant taxi only my buddy has one for sale
PostPosted: Sun Oct 12, 2003 11:55 am
It came out of a 77' Aspen. The no# is 7b424488. The car has a super six in it.
PostPosted: Sun Oct 12, 2003 2:55 pm
if it is a slant six then it is more than likely 904 i have not seen a727 behind slant six just taxi cads i will look on the numbers
PostPosted: Sun Oct 12, 2003 4:25 pm
Thanks, because I don't have anything to check the numbers by. Also are dodge trans. fairly easy to rebuild?
PostPosted: Sun Oct 12, 2003 4:42 pm
it is not rocket sci if you are mach incline i think you will have no problems
PostPosted: Sun Oct 12, 2003 7:15 pm
The easiest way to tell is a 727 has a dog-leg on the corner of the pan where the dipstick goes. A 904 is perfectly square.
The hardest parts of rebuilding a Torqflite are getting the seals in the clutches without nicking them and setting the endplay on the input shaft.
PostPosted: Sun Oct 12, 2003 7:58 pm
SSRN National Champion
Hey Bagel i think you should hunt something other than a possum maybe a frog. :D :D :D Your Racing Friend Possum Parker :D :D
talk to me bagel
