Temperature difference between locations in block
https://slantsix.org/forum/viewtopic.php?t=7024
Page 1 of 1
Author:  Pierre [ Fri Sep 26, 2003 2:14 am ]
Post subject:  Temperature difference between locations in block
Anyone have an idea of what the temperature difference is between the location of the stock coolant temp sensor and the coolant drain plug by the oil filter is?
Author:  Dart270 [ Fri Sep 26, 2003 6:22 am ]
I have run sensors at both places, and it seems to be 20-30 degrees cooler at the block plug. The factory sensor was put on the front of the head since that should be the hottest spot on the engine. I have been running my EFI with the block plug location, but I have a gauge on the stock head location for comparison.
Takes longer for the block plug location to heat up too - maybe 5-10 min more to stabilize at normal op temp.
