| Aftermarket Tachometer Question https://slantsix.org/forum/viewtopic.php?t=7043 |
| Author: | Eric W [ Sat Sep 27, 2003 10:21 pm ] |
| Post subject: | Aftermarket Tachometer Question |
Can somebody tell me how to replace the light bulb in an Equis Pro Tac mini tachometer? The light no longer, well, lights up! |
| Author: | Reed [ Sun Sep 28, 2003 8:57 am ] |
Eric- see if you can carefully take the chrome ring around the front of the tach off, or if there is a screw (or two) on the back of the tach. You probably will have to unmount it from your steering column to access the screw. Reed |
