It is currently Sun Nov 15, 2026 9:36 pm
PostPosted: Sat Sep 27, 2003 10:21 pm
Can somebody tell me how to replace the light bulb in an Equis Pro Tac mini tachometer? The light no longer, well, lights up! :shock: Thanks.
PostPosted: Sun Sep 28, 2003 8:57 am
Eric- see if you can carefully take the chrome ring around the front of the tach off, or if there is a screw (or two) on the back of the tach. You probably will have to unmount it from your steering column to access the screw.
Reed
