| Split Bench vs. Standard - Bolt in? HELP https://slantsix.org/forum/viewtopic.php?t=7172 |
| Author: | Nosser [ Fri Oct 10, 2003 2:45 pm ] |
| Post subject: | Split Bench vs. Standard - Bolt in? HELP |
I just found a 75 Dart Brougham in the local yard with the split bench with armrest in excellent condition. I believe this is a direct bolt in replacement for the standard bench in my 73 Duster, is this correct? Will the rear bench go too? Thanks in advance, I am hoping to pick it up today if it will fit, thanks. |
| Author: | DusterIdiot [ Fri Oct 10, 2003 4:04 pm ] |
| Post subject: | valiant seat is a valiant seat, but.... |
Bench is a bench to an A-body, but if it's out of a 4 door, you'll never use your back seat again the normal way..... -D.Idiot |
| Author: | Nosser [ Fri Oct 10, 2003 6:22 pm ] |
Thanks! That's what I figured so I will go scoop it up in the morning. It's out a coupe so I should be covered as far as the back seat goes. |
| Author: | DusterIdiot [ Fri Oct 10, 2003 7:07 pm ] |
| Post subject: | Are we going to call you Captain Brannigan???? |
I was just curious if it was a 'velour' model... Kinda reminded me of the 'Captain Kirk' spoof character from 'Futurama' -Captain Brannigan and his 'Velour Uniforms'... good luck on the snag -D.Idiot |
| Author: | Nosser [ Sat Oct 11, 2003 8:24 am ] |
Yup, velour as they get. It's the same maroon color as a Star Trek uniform too! Not exaclty my first choice, but it is in near showroom condition, and damn sight more comfortable than my worn out bench. Not to mention that it will not need any work when I decide to recover, while my current bench will need lots of new springs, etc. |
| Author: | 63gtcv [ Wed Oct 22, 2003 7:31 pm ] |
| Post subject: | 4 door seat |
I put a 4dr seat in my duster. Seat was out of a dart, used the seat latch mechanism/handle from a Volare. |
| Author: | mighty mouse 63 [ Thu Oct 23, 2003 1:13 pm ] |
Just threw out a split bench from a 66 Dart, didn't know there was a demand......Dave |
