| Iron Vs. Aluminum Bellhousing https://slantsix.org/forum/viewtopic.php?t=7310 |
| Author: | slantophile [ Tue Oct 21, 2003 6:40 pm ] |
| Post subject: | Iron Vs. Aluminum Bellhousing |
I have a 65 Valiant wagon that I am converting to a four speed. I have a complete /6 833 drivetrain from a 64 Valiant that should bolt right in. I also have an OD 833 bellhousing and trans from an F body. My question is --- does the z bar length and pivot point match between the aluminum and iron bellhousings? |
| Author: | Doc [ Wed Oct 22, 2003 9:50 am ] |
There are a few different OD Aluminium bellhousings that have different bellcrank mounting bosses, I am not sure if any of them line-up exactly to the early chassis. Every time I do this swap it seems that I have to oval-out some holes or weld-up a special bracket to get the bellcrank positioned correctly. DD |
| Author: | Bruce Johnson [ Thu Oct 23, 2003 10:55 pm ] |
some like the the cast Iron bell housing, but the aluminum one does weigh allot less . If you don't want the iron one I'll give you a fair price for it. Bruce Johnson |
| Author: | bud L. [ Sat Oct 25, 2003 3:53 pm ] |
| Post subject: | ? |
Yes, the aluminum b/hsg will not line up with the frame pivot on the early bodies. Yes, you can make a bracket to mount the pivot in the proper position on the later b/hsg. |
| Author: | Mike Andreas [ Fri Nov 21, 2003 9:58 am ] |
| Post subject: | Don't forget the push rod |
I used the aluminum bellhousing also. I also ended up trying a couple of different pushrods. The longest one I had seemed to make the best geometry. I ended up making a small dent in the inner finder also. Another wagon. Cool. http://homepage.mac.com/mandreas/MyVehi ... bum15.html |
