Vibration at 30-50 mph
https://slantsix.org/forum/viewtopic.php?t=7353
Author:  Jimluw [ Sat Oct 25, 2003 12:56 pm ]
Post subject:  Vibration at 30-50 mph
I just bought a '71 Dart and it has a vibration at 30-50mph. Above 50mph it seems to level out enough that it's not so noticable. Also, if I let off the gas while it is vibrating, the vibration goes away.
The front two tires have uneven wear from not being rotated. The car probably also needs an alignment. But since the vibration stops when I let off the gas, these problems seem to be unlikely culprits. Am I wrong in thinking this?
I am thinking maybe the driveshaft is out of balance, or I have a u-joint going out. Does this seem logical? Do you all have any other suggestions for me?
Author:  Pierre [ Sat Oct 25, 2003 1:24 pm ]
Possibly something in the rear end, a pinion bearing? More load is placed on it during acceleration then coasting.
Author:  VDART [ Sat Oct 25, 2003 1:56 pm ]
I believe your problem is the classic example of un-balanced tires. Before spending $$$$$$ check your front suspension & fix the tires . Your problem will most likely be solved.
Author:  Craig [ Sat Oct 25, 2003 10:47 pm ]
Sounds like u-joints. You can block up the car and crawl under and check them for abnormal movement/play/slop/wear.
Author:  Mark [ Sun Oct 26, 2003 1:39 am ]
To check the u joints pull the drive shaft out of the car. I had a 68 Valiant and after I replace the transmission with one that had a lock up converter everytime it went into lock up I had a vibration. Anyway it turned out that the holes for the transmission yoke had become enlarged enough to let the u joint slide back and forth. 2 new u joints and a yoke and it was fixed. I used a yoke for the 904 that I had that came from a van. It worked perfect and no more vibration.
Author:  Jimluw [ Mon Nov 03, 2003 5:52 am ]
Well, I changed the u-joints and all is better now. :D
Thanks for your help.
