| Bleeding procedure in FSM https://slantsix.org/forum/viewtopic.php?t=7355 |
| Author: | Pierre [ Sat Oct 25, 2003 5:02 pm ] |
| Post subject: | Bleeding procedure in FSM |
My 71 manual states, for all drums and floating caliper & drum system, to start with rear wheels and move to front. For fixed (4 piston) caliper & drum, to start with the front and move to the rear. Any ideas? I have the 4 piston setup, and started with the rears as I have known was generally proper, but my pedal still sinks a bit on the first pump compared to subsequent pumps. Wonder if bleeding the fronts first will make a difference? |
| Author: | Doc [ Mon Oct 27, 2003 1:21 pm ] |
Give it a try, I do know that the K.H. 4 piston caliper is pretty high and any air will end-up there. With the Discs, most of the pressure is set forward so that may be why they want you to bleed the fronts first. DD |
| Author: | Matt Cramer [ Mon Oct 27, 2003 3:50 pm ] |
| Post subject: | Brake bleeding tricks |
My favorite way to bleed brakes is to use Speedbleeder one-way valves. These things replace the usual bleeder screws, and I've found I can get a lot more air out using these things than with conventional brake bleeding techniques. |
| Author: | Pierre [ Mon Oct 27, 2003 3:55 pm ] |
Matt, yep I put in speedbleeders all around. They do work well, just must be careful because three pumps of pedal with one open bleeder and the resevoiur is drained. |
