| Gas and Temp question.. https://slantsix.org/forum/viewtopic.php?t=7356 |
| Author: | Swingin75 [ Sun Oct 26, 2003 8:39 am ] |
| Post subject: | Gas and Temp question.. |
Hey everyone, this is my first post on here. I've been readin through these articles and they've helped a lot. But I have one question.. "Early A-body Instrument Regulators" is about the exact problem I am havin with my gas and temp gauges. BUT I have a 75' Dart Swinger and through-out the article all references are made to 60's. Could this be my problem with gas and temp gauges totally dead? I am on my way to getting a shop manual (just bought car month or so ago) but as of now Im clueless in electrical affairs. Any ideas? Thanks, James |
| Author: | DusterIdiot [ Sun Oct 26, 2003 10:19 am ] |
| Post subject: | It might be... |
![]() The regualtor might need replacing, but also the pins where the main plug can become loose and not have contact, or the copper 'strips' can break and lose connection for certain circuits in the cluster. You wont know, until you pull the cluster (have a spare car in case it takes a while to get it back together...). You might check your 'wiring' under the hood and make sure the temp sensor isn't all gunked up(engine hasn't had a flush in a while), or the temp sensor wire (goes around the front of the valve cover from the 'coil' wiring harness, has a 'thermal/fabric sleeve' on it) may have 'grounded out', broken, or isn't tightly attached. With the gas tank sending unit, you might also check the wiring leading to the unit. Pull the wire and ground it on the frame and have a buddy see if you gauge reacts. It might be the unit, it might also bee the little 'spring clipped' ground strap that rots out (clips to the 'outgoing' tube on the sending unit, and the main gas line on the body). -D.Idiot |
