Slant Six Forum https://slantsix.org/forum/ |
66 dart motor swap https://slantsix.org/forum/viewtopic.php?t=7379 |
Author: | doug [ Tue Oct 28, 2003 9:19 pm ] |
Post subject: | 66 dart motor swap |
can anyone tell me if I can use a mid 80s slant six in place of my original 66 without a lot of changes?,thanks in advance!! |
Author: | Doctor Dodge [ Tue Oct 28, 2003 10:14 pm ] |
Post subject: | Re: 66 dart motor swap |
Quote: can anyone tell me if I can use a mid 80s slant six in place of my original 66 without a lot of changes?,thanks in advance!!
Yes, a later SL6 can be swapped into a 66You will need to change oil pans and oil pick-up tube. You will also need to add an adaptor ring to the back if the crank and use the later flex plate. All the other needed parts from the 66 engine will swap over. DD |
Author: | Raydart [ Wed Oct 29, 2003 12:39 am ] |
Post subject: | *1 Valve cover |
I need a valve cover from a 81 slant six head ![]() |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
