| help https://slantsix.org/forum/viewtopic.php?t=7461 |
| Author: | dart4life [ Fri Nov 07, 2003 9:24 am ] |
| Post subject: | help |
I put the g.m ele. ign in my 70 dart with a dist from a 79 aspen and the car is in the shop and they say that the hold down i have isnt the correct one i got it off the car i got the dist?? whats going on what did everyone else use?? thanks |
| Author: | Super6 [ Fri Nov 07, 2003 9:31 am ] |
tell your mechanic to pull the hold-down off your stock distributor and use it, assuming you had one to start with. -S/6 |
| Author: | dart4life [ Fri Nov 07, 2003 9:51 am ] |
Thanks |
| Author: | 70valiant [ Fri Nov 07, 2003 10:57 am ] |
Jared, I was really surprised to see that hold down when I pulled it from the car. all the others Ive seen have the tab with a slot but I figured it should work. or you could just swap the one from your old distributer. Phil |
