| Clicking sound from middle of engine https://slantsix.org/forum/viewtopic.php?t=7500 |
| Author: | Guest [ Mon Nov 10, 2003 6:06 pm ] |
| Post subject: | Clicking sound from middle of engine |
Well, I've noticed a clicking sound comming from the middle of my engine, which would most likely be the Carburetor. What would cause this from the carb? I dont have a vacuum leak, and that carb is a POS anyways. |
| Author: | 79Volare [ Mon Nov 10, 2003 6:07 pm ] |
sorry, this is me, i didnt log in |
| Author: | Super6 [ Thu Nov 13, 2003 12:51 pm ] |
| Post subject: | exhaust leak? |
Need to define 'clicking' a little more, but if I were to venture a guess I would say you have an exhaust leak. Small exhaust leaks where the manifold meets the head, cracks in the manifold, or loose bolts/nuts at the manifold to pipe connection create a 'tick tick tick' sound that will increase with rpm. -S/6 |
| Author: | 79Volare [ Thu Nov 13, 2003 3:21 pm ] |
That basically the sound your describing. When i had my head worked on, afterwards, i found out that the bolts on my carb were only finger tight, ive tightened them since. |
