| now what https://slantsix.org/forum/viewtopic.php?t=7509 |
| Author: | dart4life [ Tue Nov 11, 2003 2:10 pm ] |
| Post subject: | now what |
i have the timing set and the gm transistor well grounded and the car fires up runs like a champ then dies. its really buggin me thetransistor is new as is the distributet?i am toatally lost here can anyone help?? thanks |
| Author: | 70valiant [ Tue Nov 11, 2003 3:18 pm ] |
does it die when you let off the key? if so you probably need a new ballast resistor. |
| Author: | dart4life [ Tue Nov 11, 2003 3:20 pm ] |
no it will run for a good 5 sec.s then die?? |
| Author: | 70valiant [ Tue Nov 11, 2003 5:13 pm ] |
i would adjust the idle screw just to see if I had the idle set to low |
| Author: | dart4life [ Wed Nov 12, 2003 6:43 am ] |
can anyone give me some advise?? time is money! thanks |
| Author: | Super6 [ Wed Nov 12, 2003 10:14 am ] |
I agree with 70val-- Sounds like a fuel delivery problem. Double check the carb settings. If it still has a ballast, doesn't hurt to change it as well. -S/6 |
