| Fisher-harmonic Dampers https://slantsix.org/forum/viewtopic.php?t=7524 |
| Author: | TIM*LIGHTFOOT [ Wed Nov 12, 2003 2:25 pm ] |
| Post subject: | Fisher-harmonic Dampers |
HEY THERE GUYS LOOKING FOR ,A SFI AFTERMARKET DAMPER FOR YOUR SLANT 6 , WELL WE HAVE THEM ,FISHERCON1@AOL.COM IS THE E-MAIL IF YOU HAVE QUESTIONS OR WANT TO MAKE AN ORDER? FOR YOUR HIGH PERFORMANCE OR STOCK ENGINES , WILL CHECK THIS POST ON THURSDAY . |
| Author: | Doctor Dodge [ Thu Nov 13, 2003 9:59 am ] |
Tim, Thanks for the info. Do you work at Fisher? A lot of the Slant Six racers are using these, I have one and it works great. Do you know if the P/N Fisher has for the Slant Six damper is the same as the Big Bolck Mopar? (383- 400-413-426-440) DD |
| Author: | TIM*LIGHTFOOT [ Thu Nov 13, 2003 12:10 pm ] |
| Post subject: | Slant6 Harmonic Damper |
HEY THERE DOC, YES, I DO WORK AT FISHER'S, YES WE DO HAVE P/T#576307 THAT IS A MOPAR NUMBER FOR THE SLANT-6, BUT THAT UNIT DOES NOT HAVE PULLEYS ON IT SO YOU HAVE TO RUN A AFTERMARKET PULLEY. THAT DAMPER MAKES PULLEY ALINEMENT OFF ABOUT A 1 1/2 FORWARD. OUR NEW PART # 374001 WILL BOLT ON WITH STOCK ALINEMENT AND HAVE PULLEY V GROOVES MACHINED IN THE HOUSING OF THE DAMPER. COST IS RETAIL $431.00 JOBBER $325.00 BUT THERE IS ALWAYS ROOM TO PLAY P/T 576465 ,576565 ,577506, ARE OTHER V8 MOPAR NUMBERS |
| Author: | Dart270 [ Thu Nov 13, 2003 1:23 pm ] |
Tim, Are you saying that your new Slant Six damper has the pulley groove machined into it so you can use the stock belt location? I may be interested in one of those pretty soon. Thanks, Lou |
| Author: | Doc [ Thu Nov 13, 2003 1:59 pm ] |
| Post subject: | New Fisher SL6 Damper |
Tim, Thanks for the up-date and great work up-dating the Fisher Damper so it is more user friendly. I had to do a good amount of bracket fab. and pulley relocation work to run a "V" belt on my "old" Fisher damper SL6 but it sounds like you now have this problem solved. Does the new grooved damper have 1 or 2 belt grooves in it? DD |
| Author: | TIM*LIGHTFOOT [ Thu Nov 13, 2003 6:33 pm ] |
| Post subject: | Fisher/dampers |
THANKS LOU AND DOC YES THE GROOVES ARE MACHINED IN THEOUT SIDE HOUSING. AND THERE ARE TWO GROOVES IFI CAN GETA PIC OF IT I WELL TRY TO PUT IT UP ON HERE |
| Author: | Bruce Johnson [ Thu Nov 13, 2003 8:34 pm ] |
I'm in the market too, with two grooves will it line up for my power stearing in my 78 pickup? Bruce Johnson |
| Author: | TIM*LIGHTFOOT [ Fri Nov 14, 2003 12:33 pm ] |
| Post subject: | New Sl6 Fisher Damper |
OK ,OUR DAMPER HAS TWO BELT GROOVES THE ONE NEAREST THE ENGINE IS 5/8 BELT STOCK. CORRECT? THEN THE SECOND BELT IS A 1/2 BELT THAT IS .650 FROM CENTER OF REAR PULLEY, NOW IF THAT LINES UP WITH THE P/S PUMP , I DON'T KNOW. THANKS FOR YOUR QUESTION |
