It is currently Fri Jun 05, 2026 6:35 am
PostPosted: Mon Nov 10, 2003 6:06 pm
Well, I've noticed a clicking sound comming from the middle of my engine, which would most likely be the Carburetor. What would cause this from the carb? I dont have a vacuum leak, and that carb is a POS anyways.
PostPosted: Mon Nov 10, 2003 6:07 pm
sorry, this is me, i didnt log in :oops:
1979 Plymouth Volare-48k miles
Thats not nice...
 Post subject: exhaust leak?
PostPosted: Thu Nov 13, 2003 12:51 pm
Need to define 'clicking' a little more, but if I were to venture a guess I would say you have an exhaust leak. Small exhaust leaks where the manifold meets the head, cracks in the manifold, or loose bolts/nuts at the manifold to pipe connection create a 'tick tick tick' sound that will increase with rpm.
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Thu Nov 13, 2003 3:21 pm
That basically the sound your describing. When i had my head worked on, afterwards, i found out that the bolts on my carb were only finger tight, ive tightened them since.
Thats not nice...
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
