It is currently Thu Jun 11, 2026 6:43 pm
 Post subject: engine build (cont)
PostPosted: Thu Nov 20, 2003 10:34 am
I have a some more questions regarding long rod build..1) how much should be taken off head and deck for 9.3 compression?? 2) I am putting this in a dodge short box..will mounts from 71 duster bolt in?? will I need rear sump pan like V-8 swaps?? thanks again..
PostPosted: Thu Nov 20, 2003 11:22 am
One nice thing about the log rod build-up is that you can get increased compression without milling the head or block, it is a matter of selection a piston with the correct dish.
Some genreal compression ratios were outlined in the stroking article, near the end:
http://www.slantsix.org/articles/stroking/stroking.htm
As with any "custom" engine assemble, you need to take actual measurments and cc you cylinder head to calculate actual compression.
As for the engine mounts for the truck, I do not know if these are the same as the passenge car mounts, my guess it that they are not the same.
PostPosted: Thu Nov 20, 2003 11:51 am
Mounts for the truck are different than a car (at least all the cars I have seen have different mounts). The bonus is that both mounts are the same (same P/N) and from what I have seen are cheaper and have better availability than many car mounts.
NAPA had them up here, around $25 total for both IIRC.
You will need an oil pan and pickup tube for a truck as well.
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Thu Nov 20, 2003 12:34 pm
Have a truck oil pan (6qt front sump) and pick-up assembly from '60 era pick-up. Post back if interested.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
