It is currently Tue May 05, 2026 9:25 am
PostPosted: Tue Oct 21, 2003 6:40 pm
I have a 65 Valiant wagon that I am converting to a four speed. I have a complete /6 833 drivetrain from a 64 Valiant that should bolt right in. I also have an OD 833 bellhousing and trans from an F body. My question is --- does the z bar length and pivot point match between the aluminum and iron bellhousings?
PostPosted: Wed Oct 22, 2003 9:50 am
There are a few different OD Aluminium bellhousings that have different bellcrank mounting bosses, I am not sure if any of them line-up exactly to the early chassis.
Every time I do this swap it seems that I have to oval-out some holes or weld-up a special bracket to get the bellcrank positioned correctly.
PostPosted: Thu Oct 23, 2003 10:55 pm
some like the the cast Iron bell housing, but the aluminum one does weigh allot less . If you don't want the iron one I'll give you a fair price for it. Bruce Johnson
78b4ramSnortbed/6
 Post subject: ?
PostPosted: Sat Oct 25, 2003 3:53 pm
Yes, the aluminum b/hsg will not line up with the frame pivot on the early bodies.
Yes, you can make a bracket to mount the pivot in the proper position on the later b/hsg.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Fri Nov 21, 2003 9:58 am
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
I used the aluminum bellhousing also. I also ended up trying a couple of different pushrods. The longest one I had seemed to make the best geometry. I ended up making a small dent in the inner finder also.
Another wagon. Cool.
http://homepage.mac.com/mandreas/MyVehi ... bum15.html
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
