It is currently Sun Jun 14, 2026 1:32 am
 Post subject: dist.
PostPosted: Sat Nov 22, 2003 8:17 pm
What is recurving the dist.?
PostPosted: Sat Nov 22, 2003 10:12 pm
Distributor recurving is adjusting the mechinical advance to match the components / up-grades you have made to the engine.
For a SL6 this usually means adding initial advance and reducing the mechanical advance but getting it to come on faster.
Total advance without the vacuum advance should be around 30 to 32 degrees.
This article should help some:
http://www.dutra.org/doug/draft-webpage ... ibutor.htm
PostPosted: Sat Nov 22, 2003 10:29 pm
Ok where do i get this kit and is it worth all of the trouble?
thanks
Users browsing this forum: Bing [Bot] and 6 guests
